meik520
Nov 18, 2015Aspirant
WNR2200 - Vulnerability ID: NON-2015-0211
I got the warning Non-2015-0211 from my Avast scanner. Searching for that I found this message: WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2200 with Firmware V1.0.2.24 Mainte...
- Jan 08, 2016
Per our engineers, there will be no firmware updates on EOL products.
For all other products, our team is still investigating this matter.
Also, kindly make sure that you have followed the suggested solution by Avast.
Check for Alert messages stated on your Avast software. You may see this by clicking on the "Details" link.
After selecting it, scroll down and look for the "Alert messages."
Uriel23
Jan 07, 2016Aspirant
I have the same vunerability (as reported by Avast) on my JWNR2000v2. I updated the firmware to V1.0.0.11 but the vunerability remains; is there going to be any fix? Otherwise I have to buy a new router.
Furthermore, Avast says that my router is infected and my DNS had been changed - which is strange, because I switched them to manual (8.8.8.8) and dynDNS is off...
- PzooksJan 07, 2016Aspirant
I have an R6100 with the same problems and warnings.
Are there any updates available for me??
