evjayan
Jan 03, 2021Follower
WNR2200 Wireless repeater function
I am having both WNR2200 (purchased in 2012) and WNR 614 (purchased in 2017) model routers. Currently I am facing issues in the wifi range in my house, so decided to connect both the routers together...
Jan 03, 2021Guru - Experienced User
to not sacrifice speed? Hardwire the 2nd one in.
I'd actualy just look at upgrading the system. Both of those devices are base model 10/100mbps with wireless N300. They're slow from the start.
Unless you're on pretty slow dsl, they're poor performing routers
