funnyweirdo
Sep 02, 2016Aspirant
WNR2500 Wifi on/off button
I am having some issues with my wireless router not broadcasting a wireless signal any more. I have done full reboots on both the modem and router, a factory reset on the router itself and tried seve...
- Retired_MemberSep 02, 2016
factory reset it....push and hold reset button until power flashes ......if still no WIFI (default SSID found on Label) then replace it. The Modem has NO control over the WIFI.......
A properly executed factory reset will set all user settings to defaults which should include WIFI On. The default settings are found in back of the manual.
Retired_Member
Sep 02, 2016factory reset it....push and hold reset button until power flashes ......if still no WIFI (default SSID found on Label) then replace it. The Modem has NO control over the WIFI.......
- funnyweirdoSep 02, 2016Aspirant
Yeah I had already done a factory reset and when it powered back up was still not broadcasting a Wifi signal. I figured it's probably just time to replace, but thought I'd ask on here first before coughing up more money for a new one. Thanks
