rerouted
Aug 13, 2016Aspirant
WNR3500L stopped working after power surge
Eversince a brief power surge, my router will not connect. I tried disconnecting and turning off the modem, router and omputer in the proper order then turning them back on. No luck. Finally decided to try a reset. I put a pin in the reset hole and nothing happened. All I still have is a green power light.
- AnonymousAug 14, 2016
Read troubleshooting
http://www.downloads.netgear.com/files/GDC/WNR3500LV1/WNR3500L_SM_11JUN2010.pdf
- Anonymous
- reroutedAspirant
Thanks!
