Yankee420's avatar
Yankee420
Follower
Jan 19, 2022
WNR3500L v2 trouble getting to router settings login
No matter what i try i cant get to the login page for my router settings ive tried the default IP address and www.routerlogin.net and .com it just keeps sendind me in circles to the netgear router login page and tells me to download the nighthawk app which does not support my model can anyone help me out with a solution to this fustrating problem
1 Reply
  • plemans's avatar
    What modem/gateway is the router connected to?
    have you tried pulling up a command prompt in your computer and typing "ipconfig" ?
    the default gateway will be the router. (but not always if you're in a double nat)
