mr_ckw
Oct 11, 2022Tutor
WNR3500Lv2: Firmware Version 1.2.0.72 won't downlad
When attempting to download this firmware the process begins, a file is created, but no data is downloaded. Consequently I get a zero length file. Does anyone have a resolution for this issue, or, ma...
- Oct 11, 2022
Greetings,
Just used Firefox on the same computer, and it downloaded the file instantly, without issue. Thanks again for your suggestions!
Clark
Oct 11, 2022Guru - Experienced User
I just manually downloaded and extracted it without issues.
Have you tried a different device?
https://www.netgear.com/support/product/wnr3500lv2.aspx#download
- mr_ckwOct 11, 2022Tutor
Thank you for the info! I've only tried it with the Safari browser on an iMac. Knowing you were able to download and access the file is a good thing. I have other Apple devices, and, some Linux based computers. I'll see if I can have some success using those.
Again, thank you
Clark
- plemansOct 11, 2022Guru - Experienced User
Hope that works for you!
Greetings,
Clark
- plemansOct 12, 2022Guru - Experienced User
Glad to see it worked!
You can mark it solved so others aren't still trying to fix it 🙂
