mr_ckw
Oct 11, 2022Tutor
WNR3500Lv2: Firmware Version 1.2.0.72 won't downlad
When attempting to download this firmware the process begins, a file is created, but no data is downloaded. Consequently I get a zero length file. Does anyone have a resolution for this issue, or, ma...
- Oct 11, 2022
Greetings,
Just used Firefox on the same computer, and it downloaded the file instantly, without issue. Thanks again for your suggestions!
Clark
Oct 11, 2022Guru - Experienced User
I just manually downloaded and extracted it without issues.
Have you tried a different device?
https://www.netgear.com/support/product/wnr3500lv2.aspx#download
mr_ckw
Oct 11, 2022Tutor
Thank you for the info! I've only tried it with the Safari browser on an iMac. Knowing you were able to download and access the file is a good thing. I have other Apple devices, and, some Linux based computers. I'll see if I can have some success using those.
Again, thank you
Clark
- plemansOct 11, 2022Guru - Experienced User
Hope that works for you!
