mr_ckw
Oct 11, 2022Tutor
WNR3500Lv2: Firmware Version 1.2.0.72 won't downlad
When attempting to download this firmware the process begins, a file is created, but no data is downloaded. Consequently I get a zero length file. Does anyone have a resolution for this issue, or, ma...
- Oct 11, 2022
Greetings,
Just used Firefox on the same computer, and it downloaded the file instantly, without issue. Thanks again for your suggestions!
Clark
Oct 11, 2022Guru - Experienced User
I just manually downloaded and extracted it without issues.
Have you tried a different device?
https://www.netgear.com/support/product/wnr3500lv2.aspx#download
