TaterSalid's avatar
TaterSalid
Virtuoso
Nov 12, 2018
WNR3500Lv2 Has Slow Throughput on Ethernet
I have a new router that has suddenly lost throughput. It was running at 120Mbps. Now I get around 10Mbps. All switch ports are slow. Direct to the modem is 120Mbps. If I move the Internet cable to a...
  • TaterSalid's avatar
    Nov 13, 2018
    This post has gone 24 hours with no reply. Not even a condescending reply. I repeated my troubleshooting as described above. I then told Tech Support what I had done. The tech went through the usual procedures of settings and a factory reset. I am now the proud owner of an RMA.
