BigMike6
Jun 28, 2021Aspirant
WNR3500LV2 won't save unchecked "Use Router as DHCP Server" setting.
I'm trying to turn off he DNS server on my WNR3500L v2 router. Firmware is V1.2.0.66_50.0.106. I can uncheck the "Use Router as DHCP Server" setting in Lan Setup, but when I click "Apply" it comes b...
michaelkenward
Jul 01, 2021Guru - Experienced User
Can we start with why you want to do that? And what is the modem, if there is one, in front of this router?
First, though, the WNR3500L is an old (2009) Router. It has very little in common with the Mobile Routers covered in this bit of the community.
You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
