JUMBOMELON
Jun 01, 2022Follower
WNR614- enable traffic meter on netgear genie
I use netgear WNR614. I need to monitor the data usage(download and upload) of my home router. I can not find the traffic meter on netgear genie; I checked the advance tab but no option to monitor t...
Jun 01, 2022Guru - Experienced User
Probably because that device is the most basic of models. Its an single band N300 device with 10/100mbps ports and the very minimum processor/ram/flash possible to run a router.
If you're wanting more advanced features, you need a router capable of supporting them.
