Sid_Selvam
Dec 02, 2016Aspirant
WNR614 N300 disconnects while lights stay on
I have been using WNR614 N300 wirless router for a few months now. My laptop gets disconnected from internet once or twice a day, even though the router's green lights indicating wireless transmissio...
- Dec 05, 2016
Welcome to the community, Sid_Selvam
It maybe due to interference.
Try to change channel on the router.
See page 34 of the manual on how to change the channel.
Shesha_BS
Jan 11, 2017Aspirant
Hi Elaine,
Thanks for your response.
I am not using any other wireless devices on my network. ( i.e., baby monitors, microwave ovens, cordless phones etc).
Apart from my laptop, 2 mobiles connected to the same Wifi AP.
Sheeshachalam B S
ElaineM
Jan 12, 2017NETGEAR Employee Retired
How far are your devices from the router?
It might the distance.
You may also see the link below.
Troubleshooting intermittent wireless or dropped Wi-Fi connections
If that didn't help, it could be that the wireless portion of the router is slowly degrading and it might be time to get a new one.
- Shesha_BSJan 13, 2017Aspirant
Hi,
Thanks for the link. I would try the fix Fragmentation Length and CTS/RTS Threshold values to 2304. Hope it works.
I am not happy to downgrade the link speed or replace the router for a software bug. I have earlier used Huawei and DLink routers for more than a decade without an issue. It is indeed disappointing to replace Netgear wifi router every 10 months. Definitely, I would dissuage any of my friends from using one.
Hope your product software quality gets better so that everyone benefits from it.
Sheshachalam
- ElaineMJan 13, 2017NETGEAR Employee Retired
Hopefully it does.
