visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 03, 2017Aspirant
Just to verify, you're having slow wireless or wired speed?
I am having slow wireless speed as I am getting good speed by connecting network cable directly to the laptop. Direct connection speed is 60mbps and wireless speeed is not even 10mbps.
What's the speed when you connect your laptop to the router?
10mbps
What's the speed you're expecting?
I am expecting minimum 25mbps in router .
Is this working previously?
I was working till last week.
If you're having problems with the wireless speed, do you have the latest wireless driver installed on your laptop?
Latest driver is installed in laptop. We tried in mobile devices also, getting less speed there also.
What's the model of the wireless adapter?
Netgear WNR614-100INS
Did you try changing channel on the router?
Channel configuration is default.
Make sure that you avoid other wireless devices that may interfere with the signal such cordless phones, microwave ovens, baby monitors, etc.
Apart from mobile devices there are no wireless devices.
10mbps
aalexandrebeta
Mar 03, 2017Master
Try to reboot your device.
If it does not work factiry reset.
If you do still have an issue call me back!
