visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 04, 2017Aspirant
I tried rebooting the device and it does not work. Also I tried factory reset and status is same. Please let me know if I can walk to any service centre and check it
aalexandrebeta
Mar 04, 2017Master
Did you check on the wireless settings?
Did you checked the mode?
Keep me posted!
Regards
