visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
Retired_Member
Mar 04, 2017You can try ot login to the router's interface page by tying www.routerlogin.net
If asked for username: admin
password: password
Change the wireless channel to 09, 06, 11. Check for hte connection.
Try to update he firmware version.
Change the settings by connecting the computer wired to router.
Also in wireless device's probably you would get half the speed which you get from wired.
aalexandrebeta
Mar 04, 2017Master
Retired_Member you started at the begining that I should have done on the first place to visakhv!!!!!
Regards!!!!
