visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 04, 2017Aspirant
@hiteshah what the channel in wireless settings do ?
I mean if we change to channel 11, what it does really ?
aalexandrebeta
Mar 04, 2017Master
I'll explain the procedure again
login to the router's interface type www.routerlogin.net
If asked for username: admin
password: password
wireless settings menu
wirerless network 2.4Ghz section
Channel on auto
mode on the max
wirerless network 5Ghz section
Channel on auto
mode on the max
keep me in the loop if it does not solve the issue!!!
- aalexandrebetaMar 04, 2017Master
I did a mistake on this psection of procedure
Channel on auto
mode on the first one.
