visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 04, 2017Aspirant
Wireless Network (2.4GHz b/g/n)
Name (SSID):
Achi
Channel:
Mode:
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Security Options
None
WPA2-PSK [AES]
WPA-PSK [TKIP] + WPA2-PSK [AES
This is the wireless settings in my router.
