visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 04, 2017Aspirant
As per hiteshah comment, I did change to channel 11
aalexandrebeta
Mar 04, 2017Master
You can switch back to auto channel.
Can you tell me on your router if you can overpass the 300Mbps on the mode?
If yes max it out.
Make some tests and keep me in the loop!!!
