visakhv
Mar 02, 2017Aspirant
WNR614 poor speed
Hello Team, I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow...
- Mar 06, 2017It works sometime and intermittently speed goes off. We can accept this as a temporary solution and I can walk down to any nearest service center for the hardware checks.
visakhv
Mar 06, 2017Aspirant
I don't think channel change will work here.
aalexandrebeta
Mar 06, 2017Master
The question is does the "atempted solution" suits you or not.
If not it's way out of my league and my little knowledge has reached its limit!
What is your OS?
If you are satisfied kudoe appriciated.
If the solution suits you accept solution.
