luke_airig's avatar
luke_airig
WNR834Bv2, Can I make a networkable, non-wireless printer accessible wirelessy?
Hello,
I recently acquired a used Brother MFC-8860DN printer that I would like to be able
to access wirelessly. It is not a wireless printer but it is ethernet capable.
My home network consists of a wireless network router: Netgear WNR834Bv2 RangeMax NEXT Wireless Router, 802.11n and 2 wireless-enabled laptop PCs, one win 10 and one win 8.1.
Until recently I had an older PC with no wireless capability that was wirelessly accessible on my home network. It was connected to my wireless router via an ethernet cable. I also had an old hp 1210 printer (that was share-enabled) that was connected to the PC via usb and I was able to wirelessly print to the hp 1210 from either of my PCs.
I have connected my Brother printer to my wireless router via an ethernet cable as well, but it does not appear in windows file explorer on either of my 2 laptop PCs and it does not appear in the list of available printers when I try to 'add printer'.
I have connected the printer to four different ethernet ports on the router and none of them have worked.
Can anyone help me with this configuration?
TIA
Luke
  • Thanks for the reply, antinode.
    Sorry for omitting firmware version.
    port-status LED indicator on the WNR834Bv2 is solid yellow
    Installed the appropriate software on my "my 2 laptop PCs"
    Read the printer documentation
    Problem has been resolved.
    For future reference here are the steps:
    Dink around for a couple hours reading docs, connecting devices, rechecking connections between devices.
    Compose a post to the Netgear forum summarizing the problem.
    Wake up the next morning, and have the previously non-discoverable printer suddenly discoverable and accessible on the network.
    Go figure.
  • > [...] WNR834Bv2 [...]
       Nice antique.  Firmware version?
    > [...] I have connected my Brother printer to my wireless router via an
    > ethernet cable [...]
       Does the port-status LED indicator on the WNR834Bv2 indicate a good
    physical link?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the Manuals.  Look for "LED".
    > [..] but it does not appear in windows file explorer on either of my 2
       Did you install the appropriate software on your "my 2 laptop PCs"?
    Or read the printer documentation?
          https://support.brother.com/g/b/producttop.aspx?c=us&lang=en&prod=mfc8860dn_all
    • luke_airig's avatar
      luke_airig
      Go figure.
