BigTimeBookie's avatar
Jun 11, 2025
Won't accept security question answers
I have a Model R6350.  I need to access the router network site.  It wants me to reset the password, but it won't accept the correct answer to the two security questions.     I know the information...
  • BigTimeBookie's avatar
    Jun 11, 2025
    I found the answer with a little searching but I don't think I can delete this question.  Sorry for the duplication
    The answer is to reset to factory default settings.  For your particular router I suggest typing the model into your search engine and looking at the user manual.
    Have the best day!
