katmo
Nov 25, 2020Follower
won't connect to some devices
Netgear says my router is good and does not need to be replaced. My laptop, our two phones will connect to the internet. However, husband's laptop and our smart tv will not connect. This has never ...
michaelkenward
Nov 20, 2023Guru - Experienced User
ut3000 wrote:
Same issues for me ! I am really fed up with this router CAX30 . Most third class software app and router . No reliability . I try all these hard reset restart , mobile network reset some times works , some times not work . I lost trust on netgear . No consistency and omg , I just spend I think more 20-30 hrs in this year after I got this router . With our busy schedule it’s night mare.
You have joined in on an old conversation that is in a section that has nothing to do with your cable modem/router.
If you want help, rather than just to make your opinions known, then start a new conversation in the right section.
Cable Modems & Gateways - NETGEAR Communities
If you do want help, then you should provide as much information as possible.about your network and what goes wrong.
A problem with cable devices is that they rely on your ISP to get things right. Not all of them manage it. So you may be asked for details about the connection to the Internet.
