joejet
May 06, 2019Aspirant
Would like to unplug my Home wifi. and not use it. WNR2000v5
Can I just unplug my router and not use it? Traveling to Germany for an extended time. Will continue to use my laptop. This a home unit. Connected with (2) ethernet cables. I am the only user.
- May 10, 2019
You can directly wire you laptop to the Arris modem. Thats the only device that will work though and you won't have wifi. Is there a reason you don't want to use the router? The wnr2000v5 uses minimal power. Like 6 watts. Thats less than your cell phone charging.
May 06, 2019Guru - Experienced User
Sure. Its never a bad thing to shut off your network if you're going to be out of town for a while. Provided you don't want access to anything else connected at your place, you'll be fine.
