joejet
May 06, 2019Aspirant
Would like to unplug my Home wifi. and not use it. WNR2000v5
Can I just unplug my router and not use it? Traveling to Germany for an extended time. Will continue to use my laptop. This a home unit. Connected with (2) ethernet cables. I am the only user.
- May 10, 2019
You can directly wire you laptop to the Arris modem. Thats the only device that will work though and you won't have wifi. Is there a reason you don't want to use the router? The wnr2000v5 uses minimal power. Like 6 watts. Thats less than your cell phone charging.
joejet
May 09, 2019Aspirant
Have (2) Ethernet cables. (1) going from laptop to WIFI Router, (1) going from WiFi Router to my Internet provider's router. (Spectrum). I don't want to have a router anymore. Can I disconnect the Ethernet cables a go back to my provider's router without losing the Internet?
May 09, 2019Guru - Experienced User
So you're running a router and the cable provider is running a router? Or is it a modem? Model numbers and brand names would help more.
- joejetMay 10, 2019Aspirant
My router: WNR2000v5---N300 WiFi. Connected with (2) Ethenet cables. Provider's router: ARRIS-TM1602
- plemansMay 10, 2019Guru - Experienced User
Thank you very much for your advice. You have suggested that I could connect my laptop back to my provider's modem. (actually that is where it was before the WiFi hookup). Do you have a solution as to how I could connect back to the provider's modem? I think I mentioned before as to how the Ethernet cables are attached. My reason for all this is complicated to say the least. I apologize for all this and I am gratefull for all your help.
