Ocheron
Jun 08, 2022Follower
Would like to wireless bridge r6230 and wgr 614v10
Hughesnet modem with Wi-Fi disabled Rr6230 wired to hughesnet Wish to wirelessly connect wgr614v10 to R6230 so I can connect multiple non Wi-Fi devices from distance. Settings to create connection? ...
michaelkenward
Jun 09, 2022Guru - Experienced User
This does not disable the router section, if there is one, of this anonymous modem.
I can’t seem to get connection between wireless part to connect
I see no indication in the manual that the R6230, a pretty basic router, supports "wifi bridging", or repeater, mode, unlike the ancient WGR614v10, which is based on a device first launched in 2003.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model numbers and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
