plato11's avatar
plato11
"WPS is in Process" unable to change any router settings, WPS is disabled
Did anyone ever find a solution to this one?  The router works but I can't change any settings on it because "WPS is in process, please try again later."  "Add WPS client" is grayed out because it's ...
  • plato11's avatar
    Oct 06, 2017
    I made a glimmer of progress, reverting to the oldest firmware allows me to make changes to the settings without the error, but once I upgrade again to the latest firmware or any newer firmware the errors are back.
