xounet
Oct 25, 2019Aspirant
wrn2000 v5 as router or as lan hub
Hello, I want to setup my wrn2000 v5 router to extend my network. First i tried the bridge mode witch is very simple with wifi repeteater mode. But I have some lan connexions problem. Here is my con...
- Nov 02, 2019
Hello,
Since few days, and some reboots the router in AP mode seems to run well as desired. Maybe the problem came from the main modem-router (too many connexion...).
But i d like to solve the problem of airplay or dlna server device accessing when there are 2 routers in the lan network, what is the good configuration ?
xounet
Oct 26, 2019Aspirant
Thanks for your asnwer.
The firmware is the laste firmware from netgear and updated, as i said, i tried the AP mode with good connexion wan to powerline lan connexion but as i did say after 10 minutes or more, the WNR2000 is disconnected with de main router or LAN (only as AP but not as router). In that case I must disconnect the main router, then rebootn and some times I reset the powerline and that works one more time, but note very long time. I tried lots of differents connexions, parameters, all... that's why i search a solution with router mode in my case.
xounet
Nov 02, 2019Aspirant
Hello,
