dwinches
Jun 30, 2016Follower
WRT54GL wireless stopped working
I have been using a WRT54GL for a few years without any issue. Wireless and wired connections all work fine. The other day the wireless network just stopped being seen. I'm broadcasting the SSID but ...
- Jul 05, 2016
Sounds like the wireless radio died on your router. If you've tried resetting and updating firmware and it still does not trasnsmit the wireless signal it just means it's time for a new router.
ElaineM
Jul 01, 2016NETGEAR Employee Retired
Hello dwinches
You have posted in NETGEAR Community.
Kindly refer to your router's manufacturer for further support.
wcalifas831
Jul 05, 2016Prodigy
