JJNorcal
Feb 23, 2018Tutor
1.0.9.26 seemingly breaks ecobee homekit
After upgrading to latest router firmware, the iOS Home app cannot interact with Ecobee3 HomeKit. I contacted Ecobee, went through their reset sequence, but still no HomeKit connectivity. HomeKit h...
- Aug 12, 2018
Having f/w problems in another thread, which reminded me about this one, and about the fact that I had given up on homekit.
I just now successfully re-enabled homekit for the thermostat. It was quite straightforward. I don't know what could have been causing the problem when reported. I am now running 1.0.9.28.
Thought I should clean up this thread...
Feb 23, 2018Guru - Experienced User
Is the modem in bridge mode? This is a modem/router gate way. Having the ISP modem/router combo on line with the ERLite3 router can case problems.
If not, use the DMZ for the ERLite3 routers WAN IP address it gets from the modem.
Also your modem is Intel based:
Something that you should be reviewed.
JJNorcal
Feb 23, 2018Tutor
Yes, modem is in bridge mode.
I'm not aware of an Intel "badmodems" issue. Going to have to look into that.
Thanks for the pointer.
- FURRYe38Feb 23, 2018Guru - Experienced User
Is the R7000 in AP mode connected to the main host router LAN to LAN? If it is, there shouldn't be anything blocking any apps or services. The R7000 in AP mode is just passing thru traffic to the main host router. Wireless tunnel for devices to the router.
