JJNorcal
Feb 23, 2018Tutor
1.0.9.26 seemingly breaks ecobee homekit
After upgrading to latest router firmware, the iOS Home app cannot interact with Ecobee3 HomeKit. I contacted Ecobee, went through their reset sequence, but still no HomeKit connectivity. HomeKit h...
- Aug 12, 2018
Having f/w problems in another thread, which reminded me about this one, and about the fact that I had given up on homekit.
I just now successfully re-enabled homekit for the thermostat. It was quite straightforward. I don't know what could have been causing the problem when reported. I am now running 1.0.9.28.
Thought I should clean up this thread...
JJNorcal
Feb 23, 2018Tutor
Thought I replied already; apologize if this reply is redundant.
iOS version 11.2.6.
I have not yet attempted to factory reset ecobee.
I likely will first try older R7000 f/w version, as this seems more straightforward.
Feb 23, 2018Guru - Experienced User
I would try reset on this ecobee, then if that doesnt' work, try using the main host routers wifi. If it works there, then go back and revert the upgrade on the R7000 and test again...
