JJNorcal
Feb 23, 2018Tutor
1.0.9.26 seemingly breaks ecobee homekit
After upgrading to latest router firmware, the iOS Home app cannot interact with Ecobee3 HomeKit. I contacted Ecobee, went through their reset sequence, but still no HomeKit connectivity. HomeKit h...
- Aug 12, 2018
Having f/w problems in another thread, which reminded me about this one, and about the fact that I had given up on homekit.
I just now successfully re-enabled homekit for the thermostat. It was quite straightforward. I don't know what could have been causing the problem when reported. I am now running 1.0.9.28.
Thought I should clean up this thread...
Feb 24, 2018Guru - Experienced User
Both Internet and LAN ports work for AP mode. For troubleshooting though, I recommend using the LAN port on the R7000 when in AP mode to be sure nothing on the R7000 in AP mode is causing any problems. Try the LAN port. Works well.
I presume the R7000 isn't the problem in this case.
