shayne100
Apr 16, 2021Aspirant
1 more hour and my last ever netgear purchase will be returned for a refund
Netgear Nighthawk R6260 I wasted several hours trying to set up this router yesterday before calling my providers technical support team who also wasted a couple of hours trying to work out why i...
shayne100
So i need 2 routers to replace the free one from my internet provider because netgear doesn't sell routers .
Thank you hypnootoad at least i know now i wasted about £50 and 10 hours of my life because netgear are not fit for purpose .
Disgraceful . Junk . Rip Off . DO NOT BUY NETGEAR !
microchip8
Apr 16, 2021Master
You seem to be confused. NETGEAR sells routers, modems and router/modem combos. If you have a pure router, it needs a modem to connect to. If you have a router/modem combo, you can connect it directly to the plug. Your R6260 is a pure router which needs a modem to connect to. You can use the modem or gateway of your ISP (if it's a gateway, set it to bridge mode) or you can buy an ISP approved modem from NETGEAR or other vendor at your choosing.
- michaelkenwardApr 17, 2021Guru - Experienced User
Unfortunately, BT's Homehub, the devices they supply to DSL users, don't allow bridge mode. This annoys users who don't like to be tied to the Homehub, which is worth about what you pay for one, nothing. I have a couple still in their shrinkwrap.
The bad news is that Netgear, and most brands it seems, seem to have abandoned the market for DSL modem only devices. Maybe ISPs are leaning on them in the way that they have for cable modems.
If you can lay your hands on something like the DM200, that would be a good choice. The prices are getting silly. But you may be able to lay hands on a second hand one. I bought one from one of those "open box" merchants. In reality it looked new, with all the usual packing and protection.
Netgear does sell modem/routers that you can put into modem only mode, the D6400 for example, but, as I have found, that can cause problems.
As it is, we still don't know what sort of Internet shayne100 gets. (BT uses various technologies.) They seem to have dived into buying something without doing much research.
- NortonioMay 02, 2021Aspirant
Hi,
I've recently bought a Netgear nighthawk r8000 to replace my bt smart hub 2. I have FTTP and an openreach HG8110H box on the wall. I'm having a lot of trouble setting the new router up.
any advice please
- michaelkenwardMay 02, 2021Guru - Experienced User
"A lot of trouble" could mean many things. It doesn't give us much to go on.
I still think your best bet would be to follow the link I provided earlier:
Welcome to BT’s official support community.
There are many more BT users there than you will find here, and plenty of them use Netgear kit. Try a search there for your device, or any Netgear router. The settings will be the same.
Search - BT Community – Netgear fttp
For example:
Solved: Re: FTTP 910\110 - NetgearR7000 300Mbps download l... - BT Community
