mr-bonkers
Nov 03, 2021Aspirant
10-15 second signal drops hourly with R6700v2 V1.2.0.88_1.0.1 firmware
I always keep my firmware up to date, and am at the latest V1.2.0.88_1.0.1. For the last few months, every Zoom call I'm on, every IPTV program I stream, etc. experiences a 10-15 minute WiFi sign...
- Nov 04, 2021
I wonder if only a factory reset was needed in the first place.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Nov 03, 2021Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- mr-bonkersNov 03, 2021Aspirant
CableModel: NetGear CM500-100NAS
ISP: Xfinity Home Internet
5GHz channel: 149
2.4GHz channel: 11
I use various WiFi analyzers (iOS based, Android based, Windows based) and pick channels that seem best to pick, as "auto" causes a lot of interference since it doesn't actively monitor/change channels when it detects interference.
I'm in a single family home, so yeah there are neighbors all around. I get 5-10 SSIDs offered to me from neighbors, though usually their signal strength is weaker:
SSID BSSID RSSI CHANNEL HT CC SECURITY (auth/unicast/group)
chaplin52-2.4 XX:XX:XX:XX:XX:XX -87 157 Y US WPA2(PSK/AES/AES)
MIMOn XX:XX:XX:XX:XX:XX -62 1,+1 Y -- WPA2(PSK/AES/AES)
ConovanLn XX:XX:XX:XX:XX:XX -54 6 Y US WPA2(PSK/AES/AES)These are some of my neighbors
- FURRYe38Nov 03, 2021Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Okay, reduced power to 50% on both 2.4GHz and 5GHz radios. Let's see if it makes a difference.
Out of curiosity: why would that help?
