gusung75
Aug 21, 2020Initiate
16Mbps with R6900P (100Mbps from ISP)
Hi, members. I feel bad to even post this as so many similar topics have been posted and discussed. After reading through a number of postings, I decided to share my issue and seek for some advic...
- Aug 21, 2020
Thanks for your advice.
I actually disabled Dynamic QoS on the router setting which seemed to resolve the issue. The measured speed increased from 16 mbps to 80-100 on the same speed tester.
The test was done at night time when internet traffic was low. I'll see if the speed still remains similar or at least better than the initial one.
Thanks!
Aug 21, 2020Guru - Experienced User
Have you tried disabling qos?
Or tried a simple factory reset? Maybe an old qos setting is being retained and causing the issue.
gusung75
Thanks!
- plemansAug 21, 2020Guru - Experienced User
Glad to hear it was the simpler step to get it working!
