Rich-Hatch's avatar
Rich-Hatch
192.168.1.1 and 10.0.0.1 Network Map - Which one is Safer?
I have a FIOS Modem connect to the wall via coax cable, and I also shut off the wireless feature of the  FIOS modem. I purchased a Netgear R8000 nighthawk router. Everything is working great. I made...
  • schumaku's avatar
    Apr 28, 2017
    The best approach would be to operate a single (W)LAN behind the Netgear R8000 router only, so there is no intermediate TCP/IP network managed by the FiOS modem/router. To make this happen, the FiOS modem/router must be reconfigured into a pure bridge - look ie. https://www.hanselman.com/blog/SimplifyingYourNetworkWithABridgeMakingAnFIOsActionTecMI424WRANetworkBridge.aspx
    The target is that the Netgear R8000 is the only device connected to the FiOS modem/router - all other devices are conncted to the R8000 LAN and WLAN only in any case. The communication through the router between the two network you have right now are limited and highly restricted, because the R8000 does handle the current 192 network of the FiOS router as a piece of the Internet. And should you want to permit incoming connections from the Internet to your LAN, ie. to a NAS, this will be much easier if the FiOS router does not act as an additional NAT device, the R8000 does not require a special configuration, and much more.
