CPNJ
May 16, 2023Tutor
192.168.1.1 keeps redirecting to https://www.routerlogin.net. How do I make it stop?
Firmware version: v1.0.4.122 Router Model: R6700v3 Everytime I try to get to get into my router via 192.168.1.1 I am redirected to routerlogin.net. How do I get back to getting into my router via ...
- May 17, 2023
Very strange. I decided to try the same steps again and this time... IT WORKED!
Login pop-up popped up!
There are only two variables that changed:
- Time - it is now several hours later;
- typing in https://192.168.1.1 rather than just 192.168.1.1 (when I typed in just 192.168.1.1, my browser would automatically fill in the https://, so, I'm not exactly sure what the difference is when I do it versus letting my browser do it.)
The mystery is not solved, but the problem seems to be.
Thank you all for staying with me.
microchip8
May 16, 2023Master
routerlogin.net is an URL that points to your router Web GUI. It's the same thing as 192.168.1.1
- CPNJMay 16, 2023Tutor
Thank you for your response.
I am confused. How do I get into my router?
All of the suggestions I've followed on routerlogin.net do not lead me to a place where I can login to my router.
