smitty04's avatar
Nov 26, 2020
2.4 and 5 ghz not working
I purchased this router brand new from Best Buy and used it for about 6 months. It was great. I moved and unboxed it and got it all set back up in my new home and the wifi no longer works. 2.4 and 5.0 ghz lights are both of but the 60 is lit up. I Contacted customer service and waited on the phone a long time just for them to tell me it would cost even more money to have them fix it. I boxed it all back up and stored it in my basement.(I was not happy being i paid over $400 dollars for this router to not work...). I recently unboxed it again hoping that over time people would run into this same issue hoping to fix it. Any Help would be great. Love this router just feel like im out $400 dollars... Also i have factory reset it and i have tried putting older firmware on it and newer firmare nothing has changed.
    • antinode's avatar
      antinode
      Guru
      > Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
         Firmware version?  Connected to what?
      > [...] the wifi no longer works. [...]
         What about wired?
         "no longer works" is not a useful problem description.  It does not
      say what you did.  It does not say what happened when you did it.  As
      usual, showing actual actions (commands) with their actual results
      (error messages, LED indicators, ...) can be more helpful than vague
      descriptions or interpretations.
      > [...] i have factory reset it [...]
         How, exactly?  Did the LEDs do interesting things, or did you just
      flash the button (and thus do nothing)?
      > [...] tried putting older firmware on it and newer firmare [...]
         Which?  As always, actual version numbers would be more useful than
      your opinion of what's "newer" today (or "older").
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual (at least).  Read.  Look for the
      LED descriptions and "Troubleshoot".  Pay particular attention to the
      "WiFi On/Off button with LED".  Did you press it?  Further reading might
      not hurt, either.
      • smitty04's avatar
        smitty04
        Tutor
        Firmware Version: V1.0.5.24
        Wired Connection works.
        Yes i held the reset button until all the lights started flashing and I could tell it was going through the process.
        I have read through a lot of forums and i do not seem to be the only one having this issue.
        To explain no longer works.. The 2.4 and the 5ghz SSID is not broadcasting.
        The only light indicator that is on is the 60ghz out of the 3 and i have tried holding the wifi button down for 2 seconds like the manual says and it turns off the lights on the attenas and the 60ghz and i did the same process to turn it back on but again the lights for the 2.4 and 5. do not come on.
