Daveg_87's avatar
Daveg_87
2.4 GHz and 5 GHz WiFi channel width configuration
I have been trying to figure out if the WiFi channel width is user configurable for the R7000 (Nighthawk AC1900) in either the 2.4 GHz or 5 GHz bands.  I can see where and how to configure the router...
  • FURRYe38's avatar
    Try using those setting for your needs.
