Daveg_87
Sep 17, 2023Aspirant
2.4 GHz and 5 GHz WiFi channel width configuration
I have been trying to figure out if the WiFi channel width is user configurable for the R7000 (Nighthawk AC1900) in either the 2.4 GHz or 5 GHz bands. I can see where and how to configure the router...
- Sep 19, 2023
Try using those setting for your needs.
Daveg_87
Sep 19, 2023Aspirant
So, in reviewing the Wireless Setup page thru the web browser interface a little more closely I discover that I can effectively change the channel width use for both the 2.4 GHz and the 5 GHz radios/bands. The "Mode:" field for each Wireless Network (Band) has a configurable setting.
For 2.4 GHz band - options allowed: Up to 54 Mbps, Up to 289 Mbps, Up to 600 Mbps.
For 5 GHz band - options allowed: Up to 289 Mbps, Up to 600 Mbps, Up to 1300 Mbps.
The allowed channel width use for each band is set based on the max data rate selected for each. That is what I am observing.
Sep 19, 2023Guru - Experienced User
