mechbreeze
Dec 15, 2020Aspirant
2.4 GHz Authentican Problem
I recently began receiving "authentican errors" when attempting to connect to the 2.4 GHz band on my router from various devices. All credentials are entered correctly. There is no internet access ...
Dec 15, 2020Guru - Experienced User
try installing version 1.0.2.68 of the firmware. then factory reset and reinstall it. disable auto-updates and see how it works.
I've seen a couple posts with issues on the latest firmware.
mechbreeze
Dec 17, 2020Aspirant
Thanks plemans. After some more troubleshooting, I think I've traced the source of the issue to outdated firmware on my AC2200 extender. As soon as I took the extender offline, the authentication issues ceased. Now just to update that firmware...
- plemansDec 17, 2020Guru - Experienced User
which extender is it? (ac2200 is a speed)
What firmware is on it?
