JW1952
Jun 27, 2022Aspirant
2.4 ghz bird feeder
We were gifted a bird feeder with camera capabilities. The directions for the bird feeder app state to change our G from 5G to 2.4 ghz just for the app. How do I change the G setting? I see 2.4 LED l...
JW1952
How does one actually change the 5G to the 2.4G?? Thanks
michaelkenward
Jun 28, 2022Guru - Experienced User
On what?
Sounds like yet another badly written IoT toy.
With most IoT stuff, there is no need to mess around with separate SSIDs . Many, many people have connected devices using a simple and temporary fix that does not break the whole reason for buying a Mesh wifi system.
Most IoT things work on 2.4 GHz. They will not see, and cannot connect to, 5 GHz wifi.
Many makers of IoT devices use an app on a mobile device to set up the thing. Mobile devices usually connect to 5 GHz wifi and don't let you choose 2.4 GHz. The setup app should be able to connect to 5 GHz wifi and still talk to things on 2.4 GHz.
Poorly designed apps fall over because they cannot handle installation using a mobile connected to 5 GHz wifi while the IoT toy is on 2.4 GHz.
A widely used strategy that works for many people is to forget about separate SSIDs and to follow this strategy:
- Go into your router's wifi set up (see below)
- Disable broadcast of 5 GHz SSID
- Tell the mobile device to forget the connection to that SSID
- Reboot the mobile device
- Connect to the SSID
- Set up the IoT device
- Go back and reverse step 2
You may be able to miss out steps 3 and 4, depending on your phone and the app.
This approach has worked for many people.
To work out how to turn of the 5 GHz wifi, visit the support pages:
Support | NETGEAR
Feed in your router's model number and check the section in the manual Enable or Disable the WiFi Radios. The exact working may differ for your router.
