Orbidude
Dec 29, 2021Guide
2.4 Ghz Digital Frame doesn't work with RBR850 and 2 satellites...
I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took one...
Dec 29, 2021Guru - Experienced User
are they connected to wifi?
Are you able to see them on your network?
What modem/gateway is the orbi connected to?
- OrbidudeDec 29, 2021Guide
Hi,
Yes, they are connected to wifi.
I can see them in the network.
The router is connected to a Arris Surfboard S33.
Thanks!
- FURRYe38Dec 29, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Orbidude wrote:
Hi,
Thanks!
Thanks for the link, FURRYe38. I didn't know about the dedicated forum specifically for the Orbi AX (WiFi 6) products..
