ervint2
Jan 17, 2021Follower
2.4 Ghz much slower than 5Ghz
The router is R6400v2, AC1750 ISP: Cox with 1Gbps plan Actual speed from modem: Lan:600-700 Wifi: 300-400 Router Lan and 5Ghz wifi is about the same as modem, but 2.4Ghz wifi I'm only getting 80-9...
Qyooo
Jan 17, 2021Aspirant
Hey there.
2.4 GHz is will give you much slower speeds than the 5G. You can look up the reasons why, but that is the system functioning correctly.
Stay safe!
