Pat73
Aug 13, 2021Aspirant
2.4 ghz network disappeared
The 2.4g network option just vanished and only 5 g left to access for WiFi. Multiple devices run on 2.4g. Have rebooted modem and R6700 nighthawk router with no luck. Have installed the Netgear Gen...
Aug 13, 2021Guru - Experienced User
Have you tried a simple factory reset?
Push and hold reset for 7-15 seconds while powered on.
Then reinstall the router.
