Pat73
Aug 13, 2021Aspirant
2.4 ghz network disappeared
The 2.4g network option just vanished and only 5 g left to access for WiFi. Multiple devices run on 2.4g. Have rebooted modem and R6700 nighthawk router with no luck. Have installed the Netgear Gen...
michaelkenward
Aug 14, 2021Guru - Experienced User
What does the 21.4 GHz LED look like?
Pat73
Aug 14, 2021Aspirant
The 2.4 light is on but not blinking. The 5 g light is on and blinking. Read that if light is blinking means that there is activity on the line. Netgear support contradicts this. Installed Netgear Genie to view router activity online. It says 2.4 is on and ready but when I click to switch over to it, no luck.
