Pat73
Aug 13, 2021Aspirant
2.4 ghz network disappeared
The 2.4g network option just vanished and only 5 g left to access for WiFi. Multiple devices run on 2.4g. Have rebooted modem and R6700 nighthawk router with no luck. Have installed the Netgear Gen...
Aug 14, 2021Guru - Experienced User
Have you tried downgrading the firmware a version?
- JasperfaiDec 30, 2021AspirantHi there,
Do you have any update on this? My 2.4g just disappeared today…. I have Xfinity. Did you buy a new one like u mentioned? Can’t believe one has to pay to get support…..- FURRYe38Dec 30, 2021Guru - Experienced User
Reset the modem/router and setup from scratch.
Netgear has set up a community forum specifically for the Cable Modem products:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Jasperfai wrote:
Hi there,
Do you have any update on this? My 2.4g just disappeared today…. I have Xfinity. Did you buy a new one like u mentioned? Can’t believe one has to pay to get support…..- JasperfaiJan 04, 2022Aspirant
Thank you. The 7-second factory reset did the trick!!
