Pat73
Aug 13, 2021Aspirant
2.4 ghz network disappeared
The 2.4g network option just vanished and only 5 g left to access for WiFi. Multiple devices run on 2.4g. Have rebooted modem and R6700 nighthawk router with no luck. Have installed the Netgear Gen...
Jasperfai
Dec 30, 2021Aspirant
Hi there,
Do you have any update on this? My 2.4g just disappeared today…. I have Xfinity. Did you buy a new one like u mentioned? Can’t believe one has to pay to get support…..
Dec 30, 2021Guru - Experienced User
Reset the modem/router and setup from scratch.
Netgear has set up a community forum specifically for the Cable Modem products:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Jasperfai wrote:
Hi there,
- JasperfaiJan 04, 2022Aspirant
Thank you. The 7-second factory reset did the trick!!
- FURRYe38Jan 04, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
