jltaillefert
Nov 05, 2020Follower
2.4 GHz not broadcast name shows and not work R9000
My 2.4ghz band is not working, it shows active but none of my electronics (as well as my EX8000 can find it they only find the 5ghz band (guess 2.4 same) ???
Nov 05, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
jltaillefert wrote:My 2.4ghz band is not working, it shows active but none of my electronics (as well as my EX8000 can find it they only find the 5ghz band (guess 2.4 same) ???
