FISCHEAD
Jun 09, 2024Aspirant
2.4 GHZ Not broadcasting
I have a nighthawk x10 R9000 router and its never sent out a 2.4 ghz signal. I've followed all of the advice in the forums, full factory reset, turn it off, unplug everything, etc.. etc... and still ...
Jun 09, 2024Guru - Experienced User
What FW is loaded?
Try a 30-30-30 reset on the router and see if this brings the wifi radio to operation?
How log have you had the router for?
Try Voxels 3rd Party FW for the R9000?
