bpurcell
Dec 20, 2020Aspirant
2.4 v 5.0 - Switching between the two
im trying to activate smart light bulbs with my Google Assistant and the bulb app requires my WIFI to be set to 2.4 GHz. my router is currently set to run on 2.4 AND 5.0. I understand once the bulb a...
bpurcell
thanks for your reply. I dont understand everything you said re: access points and mesh systems. All I know is the bulb manufacturer (Bright) says "Verify your network and ensure your mobile device is connected to a 2.4 GHz Wi-Fi channel. Once you have successfully configured your Bright Smart device to a 2.4GHz network, you can switch back to mixed mode or ....."
I found this page (attached file) on the Router Set-up Genie and wonder if I uncheck/delete the 5GHz check box, save my setting, connect my device, and re-set the 5GHz setting - will this work?
schumaku
Dec 20, 2020Guru - Experienced User
Of course you can disable the 5 GHz wireless radio on the router in this case.
It's a little but difficult to help without information and having a wireless client device (A7000) marked - and not a router.
- bpurcellDec 28, 2020AspirantThanks. I think what I’ll do is assign the 2.4 and 5.0 different SSID names so I can select the 2.4 only connection to enable the pairing.
